Everyone is expecting that Clean Factory will produce more replica Rolex watches, as their products are regarded as the best on the market. Last week, Clean released a new replica Rolex, the Sea-Dweller 126600, also known as the Single Red Sea-Dweller. Prior to Clean’s version, only one factory, VS, had produced this model. Now, with Clean’s release, buyers are once again left wondering which to choose—VS or Clean?
Both manufacturers offer super clone versions of the 126600. Clean is known for superior details on the bezel, dial, and bracelet, while VS excels with a better movement. This reflects the general perception in the replica Rolex community: Clean offers finer details, while VS delivers superior movement quality. In the case of Daytona replicas, however, Clean stands out as the best in terms of both detail and movement.
The case of the replica measures exactly 43mm in diameter and has a thickness of 15.2mm, identical to the original. It’s said that the helium escape valve, located at the 9 o’clock position on the case, is functional. This is impressive, as no factory has achieved this before. Then again, few would be inclined to test it, as it requires a deep dive. The bracelet is also exceptional, crafted from 904L stainless steel and constructed with the same structure as the genuine Rolex. In fact, in recent years, we’ve seen significant improvements in bracelets from the big, well-known replica factories.
The movement is the Shanghai 3235, a new version that Clean upgraded two months ago. This version has a power reserve of nearly 70 hours. However, if you’re particularly focused on movement quality when purchasing a replica Rolex, I would recommend opting for the Dandong 3235 movement from VS, which has a stability comparable to the Dandong 4130.
See also  Q Factory Rolex Daytona Le Mans Gold Watch
Clean Rolex Single Red Replica
Clean Rolex 126600 Replica
Clean Rolex Sea-Dweller Replica
Clean Rolex Sea-Dweller 126600 Replica
Clean Rolex Helium Valve
Clean Rolex Case Back
Clean Rolex Bracelet
Clean Rolex Clasp
