N+ Factory Rolecks Daytona Tiger Daytona with Dandong 7750.
Thickness: 12.2mm.
Close to 1:1 replica based on the original mold.
Rolecks Daytona
  • Size: 40mm × 12.2mm (new model thickness), older model thickness 12.4mm
  • Functions: Hours, minutes, seconds, chronograph
  • Movement: Integrated 7750 movement, can be modified for hacking seconds
  • Power Reserve: 72 hours
  • Crystal: Super sapphire crystal with natural blue tint
  • Dial: Custom original-style dial, high quality
  • Case Material: 904L stainless steel, original-style quick-release end links, authentic integrated case (not from low-end factories)
  • Bracelet: AR Factory steel bracelet, quality assured
  • Bezel: Specialized ceramic bezel with platinum plating
  • Lume: Swiss luminous coating with strong brightness
  • Water Resistance: 100 meters
Key Features and Details:
  1. The Daytona watch thickness matches the latest 2024 model at 12.2mm, compared to the older 12.4mm. Other versions on the market with fake 7750 movements use thinner movements by pressing down the stem, resulting in poor stability and failing to match the original thickness.
  2. Integrated movement with engraved and electroplated bright lettering on the caseback.
  3. Steel bracelet sourced from the original AR Factory; buckle size and proportions have been upgraded.
  4. Case updated with polished bright bottom cover and improved curvature on the edge teeth.
  5. Hands upgraded by Buff Factory—three small seconds hands and the main seconds hand are custom-made, solid, with mushroom-shaped tips.
  6. Ceramic bezel features upgraded platinum plating that resists discoloration; font thickness has been refined.
  7. Dial replicates the latest white dial using Swiss ink and Korean ceramic blending and polishing, achieving a thick, pure milky white with no color difference from the original—no more dull “dead white” seen in previous versions.
  8. Each hour marker is independently CNC engraved and hand-polished on the edges. Swiss luminous powder matches the genuine glow perfectly, producing the closest visual luminosity to the original on the market.
  9. Crystal is fully transparent sapphire with no edge distortion.
See also  New Replica Rolecks Daytona models from Clean Factory
