Many factories are producing replica watches today, including various versions of the Omega Seamaster. In fact, more than ten different manufacturers are making high-quality Seamaster replicas. Most buyers only know the VS factory, but in recent times, several new players have entered the market. You might not recognize their names, but they do exist and are actively producing watches.
Previously, a factory called OR attempted to challenge VS’s position. It appeared briefly, but ultimately failed to gain traction and now seems to have vanished. At present, VS remains the dominant factory producing the best Seamaster replicas. However, many dishonest dealers sell cheaper-quality versions disguised as VS products to scam buyers. If you can’t tell the difference, you’re likely to end up with a subpar watch.
VS was the first to develop the super clone 8800 movement, initially used in the Seamaster No Time to Die. After a month of testing, they expanded its use to other Seamaster 300 models — specifically the black, white, and blue versions — which are consistently popular on the replica market.
Previously, these models used a clone 2824 movement, modified with custom plates and an automatic rotor. While reliable, it lacked the accuracy and features of the 8800 clone. With the new movement, the watches now offer a much more authentic experience:
  • Date adjustment works like the genuine version: pull the crown to the first click, rotate counterclockwise to change the date.
  • Crown rotation is smoother and more refined.
  • Power reserve has increased to 52 hours.
On the white Seamaster model, the dial is made from white ceramic, and the hour markers are filled with luminescence. There’s a slight color difference between the lume and the dial — just like on the genuine watch — although on the replica, this difference is a bit more noticeable. With time and wear, this contrast may become more obvious.
See also  Clean Factory Replica Rolecks GMT-Master II Pepsi Review: V3 vs V2+
The clasp also has some subtle differences. On the replica, the “OMEGA” and Ω engravings aren’t as deep as those on the authentic model:
  • Genuine clasp: deeper, more three-dimensional engravings.
  • Replica clasp: shallower, less defined engraving.
From the front, these Seamaster replicas are nearly indistinguishable from the real thing. However, the caseback reveals a clear flaw for those familiar with Omega movements. A noticeable issue near the balance bridge is present — a known defect in many super clone 8800 movements — and so far, the factory hasn’t resolved it.
Still, aside from that flaw, most movement details are impressively close:
  • Correct jewel placement.
  • Accurate engraving colors.
  • Decorative patterns that closely mimic the genuine 8800.
Replica Omega Seamaster 300m Blue 8800
Replica Omega Seamaster 300m Blue Ceramic
Omega Seamaster 300m Blue Crown
Omega Seamaster 300m Blue Case
Omega Seamaster 300m Blue Engraving
Omega Seamaster 300m Blue Clasp
Omega Seamaster 300m Blue Movement
Omega Seamaster 300m Blue Wrist Shot
Replica Omega Seamaster 300m White
Replica Omega Seamaster 300m Black
