I’m surprised that VS Factory acquired the Dandong 3285 movement. How did they manage to get it? Many people might not know the backstory. The Dandong 3285 movement was previously used exclusively by Clean Factory. VS is Clean’s biggest competitor in the replica Rolecks market. For Clean, VS is a serious threat because VS was the first manufacturer to use the Dandong 4131 movement in their Daytona replicas, which helped them gain many customers. In addition, VS developed their own super clone 3235 movement, making their Datejust II and 41mm Submariner replicas very popular choices.
So, facing such a strong competitor, why would Clean agree to let VS use the Dandong 3285 movement? I believe there must be an agreement between the two factories. From what I’ve heard, VS Factory had to share part of their 3235 movement technology with Clean. In return, Clean will also use the Dandong 3235 movement in their Datejust and Submariner replicas in the future.
Last week, VS Factory released the Sprite GMT-Master Rolecks replica, which features a jubilee bracelet. An oyster bracelet version will be released soon. Previously, VS published the Pepsi GMT, which received very positive feedback.
Regarding the Sprite GMT, VS Factory claims several improvements:
  • They purchased the latest genuine Sprite GMT-Master as a sample to create their replica. This allows them to replicate features more accurately than others in the market. For example, each tooth on the bezel matches the size of the genuine watch’s teeth. VS claims only their Sprite GMT has the correct bezel tooth size.
  • The bezel rotation has a better feel, with improved damping. Once set, the bezel sits firmly with zero side-to-side play—this is a major improvement.
  • The crystal is thinner than the one on Clean’s GMT, making the overall watch thickness closer to the genuine watch’s 12.1mm. VS is the only factory to get the correct thickness on the Sprite GMT.
  • The crystal also offers better transparency.
  • The minute hand has a sharper tip for better accuracy.
See also  VSF New Release: 126331 Jubilee DateJust 41mm with 3235 Movement
Currently, VS Factory offers three GMT Rolecks replicas: Batman, Pepsi, and Sprite. All are available only with jubilee bracelets for now..
Replica Rolecks GMT-Master II Sprite
VS Factory Sprite
VS Factory Rolecks Sprite GMT Replica
Replica Rolecks GMT Left Handed
VS Factory Sprite Dial
Rolecks Sprite Crown
Rolecks Sprite Case Back
Rolecks Sprite Bracelet
Rolecks Sprite Clasp
