Before VS Factory, many factories were producing Daytona reals with increased weight, including APS, Gold, Q, and CBD. Some people also mention that BT has several weighted Daytona models. However, I do not recommend any of these makers for a weighted Daytona.
First, APS and Gold Daytonas use the SH4130 or SH4131 movement, but their cases have a high risk of peeling. Q Factory Daytonas usually don’t have this case issue, but they use the same movement, and the factory charges very high prices just for adding extra links to increase the weight. Second, the newer maker CBD has bracelets that are too thick and poorly finished. For these reasons, I don’t suggest buying a weighted Daytona from any of these factories.
In my opinion, VS Factory makes the best weighted Daytona on the market. They use the best clone 4130 and DD4131 movements. They also have rich experience making this type of Rolecks, especially from their success producing the 42mm YachtMaster years ago. Unlike others, the weighted Daytonas from VS don’t have case peeling problems. Additionally, their cases and bracelets can be repeatedly gold-plated without issues. Their prices are also more reasonable.
Over the past two years, VS Factory has made major strides in the real Rolecks field. They are the main competitor to Clean and may even be outperforming them now. Below, I share pictures of weighted Daytona reals from VS Factory.
However, these Daytonas from VS aren’t perfect and have two main drawbacks, using their stainless steel model as an example:
First, the watch weighs 184 grams. Even with extra weight added, it is still about 40 grams lighter than the genuine Daytona, though heavier than Clean’s version.
See also  Is the VSF Rolecks Submariner 126610LN worth the hype?
Second, the dial’s sunburst finish looks slightly shallower compared to the genuine watch. This seems to be a consistent issue across all VS Daytona watches. Clean Daytonas don’t have this problem. I admit Clean’s Daytona has a better sunburst finish and superior hand finishing on the dial.
VS Steel Daytona with Black Dial
VS Stainless Steel Daytona
VS Pink Gold Daytona
VS Grey Daytona
VS Gold Daytona White Dial
VS Gold Daytona
VS Black Daytona with Rubber Band
Replica Rolecks Daytona Silver
VS Daytona Black Subdials
VS Daytona Silver
VS Daytona Stainless Steel Silver Dial
VS Daytona Crown
VS Daytona Case Back
VS Daytona Bracelet
VS Daytona Clasp
VS Daytona Weight
